Setup instructions
  • mickelsen
    • 94
    Setup instructions
    Where can I find a copy of the setup instructions for the microViper marine 10 that is used in the Seaview kit?
    Thanks.
    Hope is a harsh mistress!
    Mark
    Thanks.
    With the ESC hooked up to everything:
    1. Turn on the transmitter, center the throttle stick and trim lever.
    2. Turn on the SD system and very quickly, while the ESC red and green lights are blinking back and forth, press and hold the ESC programming button.
    3. Reach over to the transmitter and push the throttle stick all the way to the 'ahead' position, then pull it down to the 'astern' position, then return it to center.
    4. Release the ESC programming button.
    Done. Go forth and sin no more.
    • mtroniks
      • 12
      Micro Viper Instructions.
      Hi!
      Have a click here, should be what you require;
      Best regards, Steve.
        Originally posted by mtroniks
        Excellent, Steve. Thanks.
        I love your ESC's! I buy 'em 20 at a time. No fool'n, we provide them as standard in our 2-inch diameter SubDriver units. To date I've outfitted over 100 SubDriver's with the Mini ESC and have yet to encounter a bad ESC from your outfit -- now, that's quality!
