Viper reverse question
  • Capt. Don
    • Jan 2009
    • 5
    I have the Viper10 and the WFLY 06A with 75.57 crystals. I can't get the Viper to go into reverse. I have tried the setup many times. The servo's work. I have the viper inserted into ch 3 and it will control the speed but not go into reverse. The WFLY doesn't say it works with 75MHz.
    • 2641
    Try the servo in port/channel 3, if it works each way, the problem lies with the ESC. Crystals don't make any difference to the function of an ESC, BTW.
      I had this problem. The answer is in the instructions.
      Download them here
      Look at page two. There is a flow diagram and you need to set the 'reversible set' to position #4, which gives you instant reversal, with no delay.
      • Capt. Don
        • Jan 2009
        • 5
        Viper is working in Rev.
        I got the Viper to go into reverse yesterday. I removed the motor during the setup and set it for no lag between forward and reverse.
        • mtroniks
          • 12
          Hi. Yes, there is a 'reverse-off' function in the setup - can be inadvertantly actuated whilst setting up radio functions. See instructions, can be re-enabled! Steve.
