I'm having some trouble with the BEC on the Mtroniks Viper Marine 15 "Plug 'n Play" ESC. Once the ESC is powered up at 6.6v (little red LED is on), the lead to the Rx shows only a small fluctuating voltage (mV).
The slider switch was making intermittent connection, so I removed it and joined the wiring with solder. (I'll normally use connection to the whole subdriver to switch everything on and off.)
I've given it to a workmate who is a long time RC hobbyist, to see if he has any luck with a different voltage or battery. He also has a CRO to see what's coming out of the circuit.
If nothing comes of this, what's the best next step to get things working?
Thanks again gents.
CT.
Thanks again gents.
CT.
