Kevin
I installed the Caswell Micro Air Pump along with your Mini Controller into the Seaview SD. I am using the WFLY Radio that Caswell sells. My problem is the pump is not working using the toggle switch on channel 5. I connected it to the dial switch (channel 6) that is used for the dive plane fine tunning and the pump works fine. Is there something I need to do to use the pump with the toggle switch?
Steve
Steve
