LiPo Guard not seeing 3s
    My LiPo Guard is only showing 2 green bars instead of 3 with a fully charged battery pack. I tried two different batteries, the first a cheap one and also a Vislero. It has always shown two green bars, but I attributed that to the cheap battery. When my system went crazy, I bought the Vislero brand. Same issue. Any suggestions?
  • KevinMc
    • 305
    Hi Tom,
    Ok, first thing's first - when you say you're only getting 2 greens I'm assuming you're referring to the "voltage reading" and not the "cell count". (If your LiPo Guard isn't properly detecting that you've got a 3S battery we have much larger problems.)
    Having confirmed the above I can see one of two possibilities - either your LiPo Guard has developped a problem or your charger isn't fully charging your LiPos. Do you have a voltmeter? Can you test to see what the voltage reading on your pack is? A fully charged 3S pack should have just shy of 12.6V across it. If you've got 12.6V and only 2 green LEDs than the problem is in the LiPo Guard. On the other hand your LiPo Guard may be telling you that your battery charger isn't fully charging your LiPos. Let me know what you find with the voltmeter and we'll figure out what to do next.
    KMc Designs
      Thank you Kevin, I will get the information to you today!
        Kevin,
        I believe it is all me.....I do not believe I have been charging the batteries completely.
        Thank you for your patience.
        • KevinMc
          • 305
          No worries Tom, I'm just glad we got it sorted out.
          KMc Designs
