Snort pump control pcb
  • oztruck
    • May 2010
    • 317
    My mini snort control has stopped working. All was good and worked well, then I did a water test and a small amount of water found its way into the WTC. it must have found its way onto the board because it doesn't work any more.
    I have checked and dried everything but still no go. /any suggestions?
    Cheers Chris
    This is KMCDesigns product. I moved the post - hopefully KMC will see it.
    Last edited by Kazzer; 03-11-2012, 07:24 AM. Reason: Posted in wrong support forum
  • KevinMc
    • 305
    Hi Crhis,
    Does the LED still turn on and off as you toggle the switch on your transmitter, or is that dead too?
    Regardless, I could likely repair it but to do that you'd have to send it to me. (You could however leave the pump attached and just de-solder your power connection at the most convenient location.)
    Check your LED and we'll PM to get you sorted out.
    KMc Designs
      • 14011
      Now, that's service!
      • oztruck
        • May 2010
        • 317
        XLNT service
