ES2 Electronic switch
  • cliffhanger67
    • Oct 2013
    • 83
    Is there a way to test this switch other than in an assembly, like using a electrical tester? Mine appears to be malfunctioning. Been in service for 2 years. The pump and solenoid valve are good but not responding to command. Is the ES1 being sold on Nautilus Dry Docks the same as the ES2 I bought from Caswell? The description appears to be the same. Appreciate any help. Thanks.
  • KevinMc
    • 305
    Hi there,
    Unfortunately I don't have a straight answer for you as I have no association with the ES1 or ES2 products. I'm still willing to try to try to figure out what's gone wrong, but because they're not mine I have no more specific insight into how they work than "the next guy".
    I think the ES1/ES2 operate as un-isolated high-side switches, so you should be able to measure continuity between the Rx black wire, ES1 battery input -and power output - (to solenoid/pump). This also means that an electrical tester set to "diode test" should show you a "diode drop" voltage when measuring from ES1 battery input + to power output + when measured with the black/red leads one way, and wide open when measured with the black/red the other way. Note that these are just basic continuity checks of the power side of the circuit, if it's the controller that's gone "tango uniform" this won't tell you anything.
    KMc
    KMc Designs
      • 2012
      ES1 and ES2 are two different critters. ES1 controls one function, such as a pump. ES2 allows control of two via the same channel (IE: a pump and a solenoid), very much like the old SES-3 electronic switches from SubTech.
      • cliffhanger67
        • Oct 2013
        • 83
        Thank you. Bob clarified it also. it turned out my two ES2 are still working. so now i have 3 spare ES2. i guess i panicked and was not thinking it out to sort issues. but i never found out why for some time the two old ES2 stopped working.
