Replacement for the 3" WTC
  • roedj
    • 564
    In general, do you recommend the 3.5" WTC (if it'll fit) or the 2.5" WTC as a replacement for the 3" WTC?
    I ask this because I'm thinking of doing a couple of kits and the recommended WTC is always the WTC-3 which I believe to be discontinued.
    Dan
    David has discontinued the 3" cylinder because parts like servos, ESCs and receivers have become much smaller recently. Therefore the 'Engine Room' (Aft Dry Space) doesn't need to be 3".
    Lets now look at the ballast tank. A 6" long tank x 3" diameter = 42 cu ins (approx). A 6" x 2.5" = 37.5 cu ins, leaving a shortage of 4.5 cu ins. To make this up on the 2.5" cylinder, its ballast tank needs to be 1.75 longer @ 7.75"
    Bearing in mind that we are usually talking about larger boats, and the aft dry space can be made smaller, there will be hardly any difference in the overall length.
    Also consider the overall weight of the Sub-driver is now lower in the boat, making it more stable.
    Another important consideration is that our inventory is drastically reduced, and David's valuable time is saved.
    Hopefully that explains it for you, unless The Wizard has anything else to add (or correct).
    • roedj
      • 564
      Mike,
      Thanks for your answer.
      I've gone to the Caswell order page and I don't see a 2.5" WTC with those measurements. Perhaps it's the standard 2.5" WTC - SD25SA or SDK25SK. Is that it?
      Dan
        Dan
        Which boats are you doing?
        • roedj
          • 564
          Mike,
          Matt Thor's 1/96 Seawolf (scheduled to start this winter) and Thresher (scheduled to start next spring).
          Dan
            • 14013
            Mike,
            Dan
            Both of those kits will take the 'standard' 2.5" SubDriver, Dan.
