Caswell 3/16" shaft seals des004
  • SSBN659
    • 418
    These look like V-cup seals and I want to make sure I install them right. See my question below.
    Bill
    Bill
    I can’t remember which way round they go. I THINK it is with the brass on the inside, but then again, I seem to remember that Merriman said he uses O Rings, so it won’t make any difference.
    Suggest you pose the question on Merriman’s forum
    D&E MINIATURES SUPPORT
    Its a good question that a number of people would like to know the answer to.
    Mike Caswell Join our new Model Makers Forum! http://forum.sub-driver.com
    Hi Mike,
    I just received my order this morning and need to confirm the proper direction for installing the seals. Does the bronze end go inboard and the seal end outboard?
    Bill Rogers
    • 13983
    Bill
    Bill
    Hi Mike,
    Bill Rogers
    If it's got brass then you're looking at a shaft seal (not a pushrod seal). The cup seal is mounted with the brass (bushing) facing the dry-side.
    Stop bothering me and build/assemble something, damit.
