Capacitors for 280 motor
  • reddevil
    Capacitors
    Thank you very much. It's good to work with the best.
    Originally posted by reddevil
    Thank you for your quick response, Mr Merriman. But, How are they soldered in place? Is ti possible to have a picture about?
    Two capacitors, each soldered to a motor pole and to the motor case (ground).
    The picture below shows the two capacitors attached to a LPB motor. Not to worry, it's the same arrangement for the propulsion motor -- by the way, the Cap's are not needed on the LPB motor if you use Kevin McLeod's electronic switch.
  • reddevil
    capacitors for drive motors
    Hi from Madrid. My 1/144 SEAWOLF is fitted with one of older Mr. Merriman's WTC. It's gonna be almost impossible to convince the one that rules (my wife) to purchase the new one.
    I had to change the motor and don't remember if it has capacitors installed and their type, and due to this I'm having "glitching" problems with it.
    Anyone can help me?:wink:
    Regards
    J.C. Jorquera.
    All our motors have capacitors on the ouside of the can (.01mf)
  • reddevil
    started a topic Capacitors for 280 motor
    Regards
    J.C. Jorquera.
