Broken pitch fin on D&E Skipjack
  • llangston1
    • Sep 2013
    • 84
    While working on my 1/96 D&E Skipjack I noticed that one of the pitch plane fins has a broken outer hinge pin holder. Looks like the lower half of the small fin extension that holds the outer hing pin just broke off. What are suggested ways to repair this tiny piece of the outer hull?
    • 3769
    Dip the good side in silicon. Let it dry. Peel off. Cast and assemble on other end.
      • 3769
      Build it back up with CA and baking soda.
      Do what he said, it is much simpler than what I said.
      • llangston1
        • Sep 2013
        • 84
        I think I got it fixed for now. Super glued a metal plate made of aluminum flashing to the edge of the fin, then applied CA glue to the broken area, let it dry and drilled a hole for the hinge pin. Looks like it will work for now. I can paint it later.
        • llangston1
          • Sep 2013
          • 84
          This Metal end plate is working fine so on to the next issue. Control fin travel and yoke alinement.
