Need help with TRACKER III Transmitter
  • 639mpa
    • 68
    How do I get forward and reverse on the throttle joystick. Channel 3 (left side top to bottom movement) is not spring loaded to a neutral position. It has off to the bottom and full when moved to the top. I've only done planes before and am not sure how to set this up. I just toasted one ESC SUB10 and sure don't want to do another. See my other post.
    Thanks, Bob
  • KevinMc
    • 305
    "Off @ bottom, full @ top" sounds more like an ESC setup thing than a Tracker setup thing. Why do you think it's a radio setup issue that caused your ESC to pack it in?
    KMc Designs
      • 14014
      Yeah, you have not yet set up your ESC. Leave the transmitter end-points alone.
      Follow the ESC instructions for initial set-up.
      • 639mpa
        • 68
        That's what I was attempting when the ESC went toast. BTW the smell is aweful.
        Thanks, Bob
        • 639mpa
          • 68
          ESC
          It was an ESC problem. I got a new one from the supply dept.(Caswell) while waiting on the toasted one. Put it in and set up per instructions and everything worked perfect. Thanks for the help.
