Caswell 3.5” WTC question
  • SSN687
    • Nov 2015
    • 119
    8/25/2021 PM
    I just purchased a 3.5” WTC. The WTC was purchased from Caswell and the previous owner never got it working. I figured out the correct receiver channel and powered it from a 2S battery, I don’t have a 3s battery right now but it requires a 3S battery, and everything worked. I cannot figure out what these black boxes are for in the WTC. The ESC servo connection red power line is taped over and not used.
    WTC-1 & 2 – the part is powered from the battery and goes to a channel in the receiver. (Some sorta voltage regulator)
    Labeling as best as I can tell
    NL
    50
    ^^ MC
    7805CT
    NLBU947
    WTC-3, 4, &5 – the part is on the black lines on the ESC. (I have no idea)
    JM990A??
    LM29400
    +5.0 P
    Ernie
    WTC-1
    WTC-2
    WTC-3
    WTC-4
    WTC-5
    • 3727
    The one with 7805 looks to be a linear voltage regulator.
      • 873
      Google is our friend-and the other one is: http://www.taitroncomponents.com/cat...eet/lm2940.pdf
      • SSN687
        • Nov 2015
        • 119
        8/26/2021 PM
        OK, thank you for your answers, I’m a dumb a**. I don’t remember seeing these components installed in other WTC, why would these components installed?
          • 13922
          Originally posted by SSN687
          8/26/2021 PM
          Likely because if you blow up the ESC, you also loose all hotel services, which means no fail-safe. A BEC wired off the main power cable will provide hotel services to everything, directly through the receiver bus.
          • SSN687
            • Nov 2015
            • 119
            Thanks, makes sense now
              • 13922
              Buy Bob's book! Remote control submarines | The Nautilus Drydocks (rc-submarine.com)
