U Boat type VII/C Dive Plane Configuration
    This motor has a .875" diameter
    M280 7.2V 14000 RPM Motor $4.20
    (Sorry for the delay)
    • worzel
      • Jun 2010
      • 11
      Hello Kazzer
      Thanks for the info, is the a part number printed on it? just trying to find a spec so I can create a cad model. looks like I can now place an order for some parts from caswell.
        I read my calipers incorrectly, it should be .925" diameter.
        Sorry
        • worzel
          • Jun 2010
          • 11
          Hi,
          Thanks for the update, This still does not make sence. The motors have 0.925" 23.495mm diameter ×2 46.99mm and this fits into a tube of 44.45mm ID.
          I have found a tube in the UK which has a OD of 50mm and an ID of 45.5mm, this tube is close to the internal dimension I need but I could end up with problems.
          Do the motors you have got have two flats or are they round?
          Worzel
