gato single motor question
  • g2tiger
    • Sep 2008
    • 77
    Any one thought of trying to get just one motor in the gato? Possibly some logistic issue with a gear set up but also possibly less power use by the motors which may maen a longer patrol ability.
    Your thoughts?
    Respectfully,
    G2tiger
    • 13635
    Your thoughts?
    Respectfully,
    G2tiger
    My thoughts?
    DON'T!
      Originally posted by Merriman
      My thoughts?
      DON'T!
      AHA! I wondered when a clap of thunder would come from The Cave!
      • g2tiger
        • Sep 2008
        • 77
        Hey I was just wondering. The model runs ok on the two motors but I was thinking economy. Why I was thinking economy with a hobby that has eatin a large hole in my wallet everytime I think I'm ahead of the game....
          • 13635
          If you have to play it that cheap ... then, pal, you're in the wrong game.
          • g2tiger
            • Sep 2008
            • 77
            Not so much cheap but just trying to get the most for the dollar and save space. I was thinking that the final gearing could be in the wet area and with one motor there would be a bit more space in the wtc.
              • 13635
              Fair enough.
              Yeah, in the wet put a gear around the protruding shaft, and mesh an idler gear (same size) next to it. The shafts of these two counter-rotating gears drive the propellers.
              • g2tiger
                • Sep 2008
                • 77
                Thanks for your reply. I was thinking my next kit might suited for that project since I finally have the gato running I don't want to tear it apart. I will just have to get a second boat and amke it happen.
                  • 13635
                  Do it something like this:
                  • g2tiger
                    • Sep 2008
                    • 77
                    Nice work!
                    Looks real sharp and simple too! I shall endevor (work hard) to make something like this. BTW, I was wondering about making the Marlin hull a two prop job since I have two 40mm counter rotating props lying arond and the Marlin is under the knife so to speak.
                    Could be fun.
                    Charlie
