Tube size clarification for Snort System
  • plastic66
    • Jun 2009
    • 29
    Dave,
    In my Seaview fittings kit I received some gray tubeing size 1/8" O.D. 1/16" I.D. part # URH1- 0402 from Clippard. I am to use this on the pump jets to dog bones.
    If I want to install a snort system on my Seaview, Gato or Kilo would I use this gray 1/8" tubeing or use the 5/32" O.D. 3/32" I.D part # URTL-0503 from Clippard.
    Just want to get the right stuff for the snort systems on my subs.
    Thank you
  • pjdog
    • 302
    tubing
    Didn't your snort pump come with some black hose. Use that. You may have to use a hot nail or brass to open the black tubing a little. But it works.
    Look at the bottom of the forum page. You'll see some threads on snort tubing.
    • plastic66
      • Jun 2009
      • 29
      pj, no tubeing, all I have is the pump. I just found a thread on it. One member is useing the 1/16" gray tubeing which makes sense, since it will go directly to all the 1/16" brass tubeing on the SD. If I used the bigger gray tubing, it would not fit to the 1/16" as good I assume, that is the reason for my question.
      I know Dave gave out a part # on this, and was a bit confused because I never seen or installed a snort system before.
      I am hoping to get out to one of the sub outings where Dave hangs out and meet other people and see all this r/c stuff and have it make sense. I need to dig deeper than the internet.
        • 13968
        The same gray tube I use on the LPB is the stuff I use as the lead between the on-board bottle and blow valve. It's also the stuff used as a universal joint between the pump-jet rotor shaft and intermediate shaft in the SEAVIEW.
        It fits everything but the nipples on the LPB pump face -- you enlarge the inside diameter of the gray tube using the hot-nail trick sited above.
        I'll be at this years SubRegatta in Carmel ... but for some strange (likely nefarious) reason I'm not on the symposium speakers roster. Politics, me thinks.
        • plastic66
          • Jun 2009
          • 29
          I'll get me some of the 1/16" tubeing. Indiana is a little too far for me to travel this year.
            • 13968
            Keep in mind that that gray flexible hose has an inside diameter of 1/16", and an outside diameter of 1/8". The tube (brass) has an outside diameter of 3/32" -- this makes for a tight fit when you slip the hose over the tube.
            Just want you to understand the dimensions involved here.
            • pjdog
              • 302
              Indiana
              I love Indiana. Lived in Indianapolis for 31 years. Hated to leave.
              Jack
              • plastic66
                • Jun 2009
                • 29
                Dave,
                I tried the 1/8" O.D. tubeing that was provided in my Seaview fittings kit on the small pump. It is a tight fit, but I was able to slip it completely over the nipples with ease, I just kept the tubeing in my hands and the heat softened it up a bit. So I will need not the nail trick to slip it on.
                Also, on the Seaview SD, you provide two 1/16" brass tubes for the snort ststem and that has the 1/8" O.D. tubeing on it formimg a loop. Is not the rest of the snort system useing 1/16" brass tubeing only?
                So, If I had a an O.D. 3/32" brass tube and put 3/32" I.D. plastic tubeing over it, would it not be too loose?
                The photos you provided here of the pump motor, is that 1/8" O.D. tubeing? Looks like it is, that's what I am going with.
                Dave, one more thing. When I said I was getting some of the 1/16" tubeing, I meant 1/8" O.D. tubeing.
                  • 13968
                  Dave,
                  Let's settle on common nomenclature: 'Tube' means stiff (3/32"od) brass tube. 'Hose' means flexible gray (1/16"id, 1/8"od) hose
                  You slipped HOSE over the two nipples on the LPB compressor.
                  There are no 1/16" brass tubes anywhere on my SD's. Just 3/32".
                  3/32"id hose slipped over 1/32"od tube is a sloppy fit.
                  • plastic66
                    • Jun 2009
                    • 29
                    Dave,
                    Good, it's all cleared up in my head now. Let's move up ward and onward now. Thank you for taking the time to answer my questions and your concerns that I understood all you said. You explain everything very well, you are a good man Dave.
                    Shawn
                      • 13968
                      Dave,
                      Shawn
                      Good man?! .... I'm a frig'n God!
                      Clarity is the essence of success.
