Charging???!!!
  • Kim Sleep
    • Nov 2013
    • 329
    Charging???!!!
    I have a question regarding the charger sold on the sub driver website.
    The charger has a T type connector on it, usually reserved for power in/out connections only. The batteries sold on the website have the traditional white BALANCE connector (don't know the name) usually reserved for charging, as well as the T-connector for power out. Does this charger connect directly to the power out connector of the battery, ignoring the white balance charging connector??
    Thanks in advance...
    • 13625
    No need to balance charge our submarine batteries -- we're not competitive drivers. Don't sweat it. Charge through the two-pronged plug and you're gold, Kim.
    • bwi 971
      • Jan 2015
      • 940
      I’m not going to argue with his majesty I’m just going to explain to him why I’m right.
      NO I DON’T WANT TO BE RIGHT, THAT STATE OF MIND START WARS
      (he will call me a ***^¨¨¨*****$$**pain in the ass anyway, but that aside)
      I just want to point out there is a middle way in buying an expensive top notch top dollar charger with balancing ports and a charger with no balancing ports like the subdriver charger.
      In my opinion you need to balance multi cell packs, if not with every charge then certainly on a regular basis.
      Balancing Li-Po battery packs ensures that each cell matches the voltage of the other one, or as closely as possible, your LiPo's will live longer.
      You can by a separate Li-Po balancer and use it in conjunction with the Subdriver charger, and they’re not expensive.
      This way you have all the goodies for less money and you LiPo’s will last forever.
      Grtz,
      Bart
      "Samuel Smiles"
      • Kim Sleep
        • Nov 2013
        • 329
        Thank you both very much, as per usual, my question has been answered in a intelligent answer. Both of you have experience far beyond my level, and I am lucky to be able to tap into it.
          • 13625
          I have no argument with Bart. He's absolutely right. But, my basic approach, though tough on the battery, and results a less than ideal cycle life, is good enough for us. I've got six-year old packs that I use on a regular bases that I've never balanced. I'm sure if we analyzed them we would find a significantly reduced capacity from factory fresh because of the differential voltages between the cells.
          I'm the pragmatic sort -- good enough is less aggravating than the expense and effort required to approach perfection.
ID:	98933 Click image for larger version
          • Kim Sleep
            • Nov 2013
            • 329
            Ok, while I have everyones attention, in regard to batteries...what is the best way to store lipos over a long term (such as winter), as well as short term
            • bwi 971
              • Jan 2015
              • 940
              If you Charge them at half of their capacity you will be fine......when you need them you can fully charge them, no harm done they don't have a memory like the NiCa.
              Grtz,
              Bart
              "Samuel Smiles"
