Independent Shaft Control
    • 13936
    The Revell Type-7 turns just fine. Don't sweat it.
    • satlite440
      • Jul 2012
      • 177
      I do not have experience with the mixer, but does the sub need it? As I understand and will soon find out, the type VII has very good maneuverability as it is. The site is cool and all. I looked at this site a while ago for the Aluminaut - the circuit boards are too big.
      the p82 is 33mmx23mmx16mm in the case.. you can get it with no case and it would be smaller...can't find the ciruct bord size.. but think it would fit with out a case for the 2 esc's and mixer... as to turn rate i know the sub turns fine as is.. like i said i was thinking about another moter bulkhead&moters&tray to try and see if i could fit it in to my 2inch s/d as a later upgrade...
        • 3731
        I was not clear, it was too big for the Aluminaut. Yep, go for it! Post here so we can see it.
        • small sub guy
          • Dec 2009
          • 45
          My radio with Robbe Dual Stick unit installed
Name:	2012-11-09 18.58.08.jpg
          • small sub guy
            • Dec 2009
            • 45
            My other radio with internal pot added so that one stick controls two channelsClick image for larger version
Name:	2012-11-09 18.57.45.jpg
