Building the RC Shark - how much Dielectric Grease to use in Battery Connector
  • igrover
    • Apr 2026
    • 2
    Hi - I've never had to waterproof any project I have worked on. It is recommended to use dielectric grease on the battery connector in the RC Shark however I do not know how much to use. A tiny bit? Fill the entire connector hole with grease?
    Thanks in advance.
    I slather it in there and let the excess press out. Wipe it off and you're good to go.
    • igrover
      • Apr 2026
      • 2
      Thank you.
