Iniciantes, dicas
    • 981
    #31
    This You tube video as some great images and close up details in places. Enjoy.
    Stills:
      As you have a lathe I would machine the end caps of the dive module from some plastic stock rather than print them. Machining from solid will give a more accurate result and as long as they’re machined accurately much less chance of leaks as the material is homogenous. I like pvc for bulkheads as it machines beautifully and is very tough and inexpensive, but you can use most plastics e.g. acrylic, polycarbonate etc. you’ll see a lot of dive modules/wtc’s with resin cast end caps, this makes sense for batch work or complex shapes but not for one or two items of a simple flat endcap, and resin is not as tough as most thermoplastics unless reinforced with glass or carbon.
      • Osmar da Silva tomim
        • Sep 2025
        • 27
        #33
        Stills:
        thanks. Very good. I'm going to use it to try to detail mine!
          • Sep 2025
          • 27
          #34
          Great idea. I'm going to do this on my lathe. Thanks for the tip!
            • Sep 2025
            • 27
            #35
            I started printing the S80, on my printer, Creality v3 ke. The first piece printed very well, but now the piece comes off the table right away. I changed the printing position during slicing and it started well, but when it was at 80% the piece "broke" and split, then it went bad, I had to stop printing. But I'm not able to print, it comes off the message right at the beginning of printing. Can you give me any tips?
              • Sep 2025
              • 27
              #36
              it comes off the table right at the beginning of printing! I've tried many things, even applying a spray for this, but it didn't help.
                Try printing the piece on a raft.
                  • Sep 2025
                  • 27
                  #38
                  What does it mean to try printing on a raft?
                    Seriously?
                    What slicer are you using?
                      • Sep 2025
                      • 27
                      #40
                      Seriously?
                      I'm using the Creality printer's own slicer
                        Take a look at this. https://youtu.be/JjlzkroHnUY?si=h4xv2RktTZ_WfiGk
                          • Sep 2025
                          • 27
                          #42
                          obrigado!I'll take a look
