so I took the plunge and bought nearly completed 1/72 VIIC with a Subdriver from IR3 ... now I imagine the documentation he mentioned comming with it will probably have alot of the info I'm asking about .. but thought I would ask anyways to see what I can find/have comming before it gets here
my main question is about the grease to use for the WTC seal rings, and the pushrod seals?
and he mentioned I'll need to pick up pushrods... what should I be getting? and I see from a post about hooking up all the shafts to the WTC looks like magnets are used ... is there a kit ? or?
thanks
Reckless
thanks
Reckless
