Early SAS set up
    • 3603
    Early SAS set up
    do you still have a copy of the article or photos of your initial semi-aspirated system, the one were you used those mini pneumatic valves?
    • 13797
    If so it's likely one of the Cabal Reports, and if still around is buried somewhere on Bob's site. Here are pictures from that early SAS configuration and component tests.
      • 3603
      Thanks. Wanted to compare it to Philip Shelton's (RevellU505Late) set up in his Revell 1/72 Type IX conversion. Click image for larger version  Name:	20230827_230109.jpg Views:	0 Size:	74.8 KB ID:	173350 Click image for larger version
Name:	images (1) (10).jpg
      Brief description about his SAS
      Originally posted by RevellU505Late
      Back to the diaphragm pump, which also is not air tight when at rest. So how was I going to control the flow of air in both directions? I settled on two micro valves. A two port valve to stop the airflow when the pump was at rest and a 3 port valve to allow air in and out of the ballast chamber.
      I also extended a brass tube along the top of the ballast chamber and stopped it in the middle, cut the end on an angle and bent it towards the top so that in the event of the chamber completely flooding, the tube would see the last available air. Also, the air intake and exit uses the entire WTC, so air is pulled or pushed through the WTC and the antenna/snorkel tube. The air supply exit at the aft bulkhead is near the top, but has a short silicon tube that extends down to the bottom of the aft chamber. This is to prevent any water that might enter from dripping on the motors and electronics.
