D&E Sub-driver 3.0 Not supported anymore?
  • mostpeople
    • Aug 2011
    • 6
    Hey all,
    I have a D&E Sub-driver 3.0 which I use in my 32p type XXIII, unfortunately it has sprung quite the leak in the forward bulkhead. Essentially it is not sealing anymore. I do not know if the resin bulkhead has shrunk, or if the O-ring has worn down? It is old, obviously, so I am going to start under the assumption that it is the O-ring.
    My question therefore is, Dave, do you not support this Sub-driver anymore? Where could I get the correct O-ring this thing was designed to use? Thanks.
    -Chris
    It might be a good idea if we could persuade Mr. Merriman to make a list of all the Sub-driver sizes and their respective O-ring values?
    In the meantime, perhaps you could try wrapping some PTFE pipe thread tape in the O-ring groove. Several turns will make the ring expand more.
      • 13988
      Originally posted by mostpeople
      Hey all,
      -Chris
      You need the forward ballast bulkhead and o-ring? I can fix you up.
      dmeriman@aol.com
      • mostpeople
        • Aug 2011
        • 6
        I am worried the bulkhead may have shrunk, is that possible? Either way i need a forward and an aft bulkhead oring to start, the other ones are shot.
          • 13988
          Need an address.
          • mostpeople
            • Aug 2011
            • 6
            Pm'd you an address, did you get it?
              Oh! Dear! I don't think His Eminence knows how to open a PM. I've sent him thousands and never got a response.
              Better pm me, and I'll make sure my owl delivers it for you.
