Hi all,
Any advice as far as WTC placement in the hull goes? Is lower better? I can make the the WTC line up level with the drive shaft but it will raise the WTC about 3/4 to 1inch off the bottom of the hull. Alternatively I can put it low in the hull and use a u-joint.
is there a best practice?
thanks,
Ryan
thanks,
Ryan
