Carbon Fibre Pushrods
  • hywel
    • Aug 2022
    • 65
    I bought a bunch of 500mm carbon fiber rods to reinforce my hull, but then found 1000mm ones that will work much better.
    I figure I can use the short ones for the rudder/dive plane surfaces but what do y’all think of using hem for pushrods? They have a little flex so if things get jammed up they could be more forgiving than straight up brass rod, but…anyone used them like this though?
    Thoughts?
    cheers,
    - hywel
    Say a small grit of sand got wedged between the hull and stern plane right after you commanded a dive. You pull back and nothing happens, the control rods just bowing everytime the servo moves. A rigid rod could transmit the power needed to dislodge the jam.
    • SubDude
      • 825
      What diameter rods?
        • 898
        I would suggest tubes not rods-fill the tube with foam...VERY rigid. CF rods and tubes are pricey with min buy...
        I am now going with a Sullivan control cable in guide tube-(plastic in plastic with provision for a 2/56 ss treaded coupling rod to connect a Dubro plastic quick link) -No metal to metal/inexpensive/ readily available/ RC model aircraft proven/ no trapped air /flex if needed and no corrosion.
        • hywel
          • Aug 2022
          • 65
          Originally posted by SubDude
          What diameter rods?
          That would’ve been helpful to share right? 3mm
          • hywel
            • Aug 2022
            • 65
            Good point. The brass stuff will show up in a few weeks, I can use this stuff for other projects. Thanks!
            • hywel
              • Aug 2022
              • 65
              Sounds like a good plan for the next boat (oh there will be another if my tanks are anything to go by!). Cheers!
