Base loaded antennas
  • Mooneyjock
    • Jul 2021
    • 15
    Looking through the resources, I haven't seen anyone using the short (12"-15") base loaded 72-75 mHz whip antennas that are used on cars, boats and sometimes airplanes. Will they work in a submarine? I am assuming not. Why?
    Thanks, John H.
    • 873
    I could be wrong but The citizen band freq is between 26.965 MHz and 27.405 MHz. If you want a kicker for your subs transmitter, you'll have to make it for your frequency- I think it would probably work. (Build one and do a walk test)
    • Mooneyjock
      • Jul 2021
      • 15
      Thanks Bob, The small antenna's I am referring to are ones commercially produced by Kraft and Ace for their R/C receivers. I have a bunch of them and have been using them on small airplanes to replace the long wire antenna's. I was wondering if anyone has used them in subs, or if problems have been found.with their use. I was thinking that they would simplify the antenna placement, as they could easily fit inside the WTC.or outside in the hull.
        • 1622
        Thanks, John H.
        No need. 72 and 75 works with antenna that comes with the receiver, without the need for any external one,
          • 1622
          CB is 27 MHz. and has nothing to do with 72 and 75 mhz.
