Installing a momentary switch inside the subdriverr
    • 3513
    I want to retrofit a momentary switch on the ballast servo bracket of my Kilo SD to activate the LPB to blow ballast in lieu of gas. Would it be possible to remove the bracket without the need to remove and reinstall the rear ballast tank bulkhead? Click image for larger version
ID:	151063Click image for larger version
ID:	151064Click image for larger version
    • 13699
    I do it all the time. You?...
    Show me something you've assembled lately.
      • 3513
