Skipjack question
  • secrtwpn
    • Feb 2012
    • 182
    Skipjack question
    I made a slight error on assembling my Skipjack. I need to buy more cardstock to secure the forward part of the hull. What is the thickness of the supplied cardstock? My calipers are not that accurate.
    Thank you,
    Farlan
  • secrtwpn
    • Feb 2012
    • 182
    ..................Make that the "Forward Radial Flange.......................
      • 13933
      Thank you,
      Farlan
      .030 - .040 inch will do it.
      • secrtwpn
        • Feb 2012
        • 182
        Thank you sir
        • secrtwpn
          • Feb 2012
          • 182
          Next question.....I'm having issues attaching the upper hull to the lower hull. I slide the upper hull over the front radial flange and am having trouble lining up the indexing pins on the upper and lower hull. Are the indexing pins to be removed?????????
          Thanks again
          Farlan
            • 13933
            Thanks again
            Farlan
            Not removed. Shortened. A little at a time till the pins fit the holes. Patience!
            • secrtwpn
              • Feb 2012
              • 182
              Which ones shorten? The male or female pins?
                • 13933
                Male......................
                • secrtwpn
                  • Feb 2012
                  • 182
                  Thank you.....
                  • secrtwpn
                    • Feb 2012
                    • 182
                    This is continuing education (but I'm not getting frustrated)........I opened up my 3.5 " cylinder and found out my micro servos are too short for the servo foundations. I test fit an old full size servo and it was too long.........So, my question is, what size servos are to be used? I could redrill the holes and move the aft servo foundation further forward. Also, I took your advice and gradually cut down the male pins on the upper hull and it fits much better......
                      • 13933
                      Yeah. Move the after foundation forward a bit. Duh!
                      • secrtwpn
                        • Feb 2012
                        • 182
                        Roger that!
                        • secrtwpn
                          • Feb 2012
                          • 182
                          Next question. Where does the bare wire coming out of the pump Click image for larger version
ID:	146883 connect? I figure the plug goes into the RX.
                          Thank you
                            • 13933
                            Thank you
                            Red and black wired in parallel with the main battery cable -- observe polarity or things will go terribly, horribly wrong! The servo lead goes to the output side of your fail-safe/BLM/LipoGuard/Flux Capacitor/Whatever as one leg of a Y-lead. The other leg goes to the ballast sub-system servo.
                            • secrtwpn
                              • Feb 2012
                              • 182
                              Got it! Thanks again
