Hello all, is the prep procedure for painting plastic the same as prepping Resin?
Prepping Plastic for Painting
Who is John Galt? -
Scrub with a T-shirt saturated with the recommended solvent. The T-shirt is abrasive enough to scrub away oils and gunk, but soft enough not to abrade away detail on the models surface. The mild hydrocarbon solution is active enough to cut grease, and wax, but not so volatile that it will attack most substrates employed by model assembler/builders.
Who is John Galt?Comment
Soak the T-shirt in the https://www.amazon.com/SEM-38374-Sol...-9&tag=mh0b-20 scrub the work, let it evaporate and you're ready to putty/glue/prim/paint/weather/apply markings. No water.
DavidWho is John Galt?Comment
