What glue can I use to bond plexiglass to fiberglass?
What glue to bond plexiglass to fiberglass hull?
Tags: None
Strongest would be a modified acrylic glue e.g Devcon plastic welder, stabilit express, super crylic etc. A bond with that is stronger than the substrates.Comment
Whatever glue you decide upon my first question would be is the fiberglass hull epoxy glass or polyester glass? If it is epoxy glass by all means make sure you wash it with soap and water to remove the amine blush, or waxy film that rises to the surface of an epoxy finish which will prevent any glue from sticking... A polyester fiberglass how will also probably have parting agent still on the surface from when It was in the mold... Also wash the surface hot soapy water and a solvent ... And you must sand both surfaces of contact to provide a tooth for the glue to grip. But make sure you clean the surface before you sand or you will just be sanding the parting agent or amine wax into the items you're looking to bond.-BGComment
