Question on Skipjack fittings.................
  • secrtwpn
    • Feb 2012
    • 182
    Is the sail plane bell crank meant to swivel on the brass bar going through the middle of it; or is the brass bar CA'ed to it and the bell crank swivels on the sail plane shaft retainers? Hope this makes sense.
    Farlan
    • 3658
    Farlan,
    the bell crank is fixed to the rod. The rod will rotate on the shaft retainers.
    Tom
    • secrtwpn
      • Feb 2012
      • 182
      Thank you. That makes sense.....
      • secrtwpn
        • Feb 2012
        • 182
        The photos help! Thanks
        • secrtwpn
          • Feb 2012
          • 182
          Tom,
          Did you remove the aft alignment pin that the aft foundation butts up to?
            • 3658
            Partially. I ground out the top for airflow. Click image for larger version
Name:	Skipjack mounting sail.jpg
            The area marked by a Sharpe will be removed.
            Does this help?
            Tom
            • secrtwpn
              • Feb 2012
              • 182
              Yes it does. Thanks!
