Icing up in the ballast system
  • secrtwpn
    • Feb 2012
    • 182
    Today, I was getting my 2.5" Sub driver ready for a lake trip (hopefully soon). When I filled up the tank, I noted there was icing in the system and it would not do a blow. The contact is pushing on the Schrader valve, but no propellant is coming out.........The tank still has propellant in it. I did have a blowout of the valve in the first photo and I was able to put it back together, although not as tight of the factory setting. I have attached two photos.....
    • 12311
    the frosty blow-valve tells me that the valve itself is leaking. Put water in the ballast tank and you will see bubbles of propellant gas getting by the Shrader valve.
      • 1777
      What he said.
      Icing occurs with prolonged discharge or discharge of gas at too high a rate. Many times immersion in the water will make the icing much less likely to occur, but you don't want a leak.
      Of course, you're doing your pre-run cylinder check every time, so spotting this leak would have happened anyway, right? Right? ;)
      • secrtwpn
        • Feb 2012
        • 182
        Well, sort of. I charged the tank and did the leak test. Very small amount of bubbles coming from the internal Schrader valve, but no gas. I operated it a few times with success, but then nothing came out. All of a sudden, a large bang and the aforementioned hose came loose again! Any way to fix this???????
          • 1777
          Yep. Replace the hose... ;)
          You'll need really steady hands and thin gripping tools. This is one area that the new MSD subdrivers really shine. The original SubDrivers worked amazingly well, but performing maintenance and/or repairs is challenging.
          I can't see where this failed. Is that at the restrictor? You might be able to get away with cutting back 1/4" of hose and simply re-attaching.
          • secrtwpn
            • Feb 2012
            • 182
            I see a way to do it. I'll give it a try.....
            • secrtwpn
              • Feb 2012
              • 182
              Another quick question: a source for the hose?
                • 12311
                Send me your mailing address and I'll fix you up with some hose and hose-collars.
                • secrtwpn
                  • Feb 2012
                  • 182
                  Farlan Clutters
                  13528 Live Oak St.
                  Hesperia, California 92345
                  Thank you! (your PM was full)
                    • 12311
                    Farlan Clutters
                    13528 Live Oak St.
                    Got it. Thanks.
                    • secrtwpn
                      • Feb 2012
                      • 182
                      Got the parts! Thank you!. That will help!
                        • 12311
                        excellent...…………..
