Overfill Switching???
  • Kim Sleep
    • Nov 2013
    • 329
    Ok, for some reason, this has me flummoxed.
    If a sub has a bag , with an overfill micro switch, once the switch is tripped and therefore the pump is turned off, how do you then bypass the switch, so that you can restart the pump to empty it the bag??
    • 13625
    Put the second switch in parallel with the first switch. Duh!
    • Kim Sleep
      • Nov 2013
      • 329
      I guess I should have said thathow is this all switched without using up a ton of channels??...Hey nobody said I was smart...just good lookin'
        • 13625
        Is making it a three-position switch an option, Kim?
          • 2503
          There are a couple of ways of doing this, all from a single channel. method used depends on the type of pump used. Are you using a reversible pump?
          • type7
            • 189
            If you add a diode to the overfill switch, it can shut off current flow in one direction but allow you to flip the switch and drain the bag when using a reversible pump. This is what rc subs out of Hong Kong does.
            • Bob Gato
              • 873
              Yes- I posted this in tips and tricks a short while back-its a different system but the blocking diode works the same (instead of a pressure switch insert your limit switch Click image for larger version
              • Kim Sleep
                • Nov 2013
                • 329
                Holy crap....lookit that. Just to add, my pump is reversible peristaltic. I would prefer not to have to use a pressure switch if possible.
                • Bob Gato
                  • 873
                  Originally posted by Bob Gato
                  -its a different system but the blocking diode works the same (instead of a pressure switch insert your limit switch) Click image for larger version  Name:	image_40797.jpg Views:	0 Size:	68.9 KB ID:	135943
                  Please reread the narrative...especially the last nine words
                  • Kim Sleep
                    • Nov 2013
                    • 329
                    As I am using a bag, I dont think that I can use a float switch, Im sorry Bob, you spent time with the great, easy to understand illustration. So any ideas on Bag switching??
                    • Bob Gato
                      • 873
                      Click image for larger version  Name:	P1080024.JPG Views:	0 Size:	42.8 KB ID:	135960 Sorry-that was a diagram of my sub-that wasn't a float switch its a "clunk" so the water is always pumped from the bottom of the tank (which you don't have)
                      Lets start from the beginning...this diagram might be easier...
                      • Kim Sleep
                        • Nov 2013
                        • 329
                        Ok, Tah-Dah...now I understand that.
                        • Kim Sleep
                          • Nov 2013
                          • 329
                          Any configuration of switching is available.
