Using an FrSky X18 + TD-S6R for Submarine Control
  • Fishb0y
    • Jul 2023
    • 167
    This is the process I followed to move the stern planes to the slider and the bow planes to the right stick. I’ve also included a link to a my stabilized model file you can upload directly to your radio… though the real question is: is it truly a model, or just a bootleg copy of Midnight Movie Massacre (1988)?
    Step 1. Understand How the S6R Stabilization Works
    • The S6R expects one stabilized elevator channel (normally CH2) from the transmitter.
    • Stabilization is applied on the channel level (not on the stick), so whatever source drives CH2 will get stabilization applied.
    • Therefore, we just need to map CH2 → Slider (S1) instead of J2 (stick).
    Step 2. Reassign Elevator to Slider
    1. On the X18, go to Model → Mixer.
    2. Find CH2 (Elevator).
    3. Delete the default elevator mix line (linked to J2).
    4. Add a new line on CH2:
      • Source → move the right slider (S1).
      • Save.
      • Now CH2 is driven only by the slider.
    5. Run the Stabilization Wizard again if needed — it will bind stabilization to whatever is on CH2 (now S1).
    ✅ At this point, the stern planes (CH2) are stabilized and follow the slider.
    Step 3. Set Up Bow Planes on Stick
    1. Pick a free channel for bow planes (say CH6).
    2. In Mixer, add a new line:
      • Channel: CH6.
      • Source = Elevator Stick (J2).
      • Weight = 100%.
      • Save.
    3. Plug your bow plane servo into CH6 on the S6R.
    ✅ The bow planes now follow the stick directly, with no stabilization applied.
    Step 4. Verify on the Bench
    • Move the slider (S1) → stern planes move (and wiggle with stabilization).
    • Move the right stick (J2) → bow planes move only.
    • Stabilization should only act on stern planes (CH2).
    • 13980
    This. Means. War! OK. Gloves off. Gotta find your Achilles-heel, pal!
    • Fishb0y
      • Jul 2023
      • 167
      Until Jitter Bug starts making RC radios, I feel it's my duty to help out where I can!
        • 13980
        What you're passing on to Jake is now being translated to Torpedo-speak, at which point he'll prepare carefully worded flash-cards for me to use as I work to make my r/c system much smart. Thanks for the work you're putting into this, Steve.
