For the brave (and technically adept)
  • QuarterMaster
    • Sep 2015
    • 1240
    Another tip for the X20(S) fan. X18(S) similar(?)
    A nice thing to point out is the throttle, for 99% of you who use left stick as it, can be switched from ratcheted to smooth friction. Allowing a more finer control while preventing "floppy" stick.
    I use the left pot for throttle, and my stern planes are on stick 3 so I prefer the ratchet and fine tweak with trim. Just a thought.
    FrSKY X20S Gimble Spring and Throttle Adjustment Tutorial
    FWIW, DON'T be afraid to remove that back cover! Just watch the side pots and the antenna cable as he said!!
    You can then swap switches easy enough! IE, 2x 2 pos return, or swap in a 3 pos center return!
    Fortune favors the bold!
    v/r "Sub" Ed
