Fictional Kriegsmarine Typ XXX nuclear attack sub
    • 1118
    Click image for larger version  Name:	20180523_205027_copy_2064x1548_1.jpg Views:	0 Size:	59.5 KB ID:	197572 Click image for larger version  Name:	20180523_205213_copy_2064x1548.jpg Views:	0 Size:	58.8 KB ID:	197571
    Hello!
    This is my second Arkmodel Redshark RC submarine Kit conversion. I started it around 2017/2018, originally i retained most of the model as-sold, only changing the looks into a (to me) more attractive design, modifying the servo horns, engine mount and adding a piston balast tank etc. See pictures in the attachment, they wont show up in the post!
    The boat was then ready, only missing painting it.
    1,5 years later i figured the electronics, i.e. the corona receiver, were not working anymore for unknown reasons. After replacing it, i found there was still more to do on the boat and started all over again. The original upper deck got loose etc.
    So i tried several new configurations to turn the boat into something more realistic, including conversion into an Akula-III after making a scale master model for the conning tower, a Charlie I, again with making molds for extra parts( sail, bow, sterncone). However i kept returning tp my original idea, a minimalistic model based on the original kit. I very much like the plane-like atrangement of the large forward bowplanes like on early british nukes.
    Click image for larger version  Name:	IMG-20230408-WA0006_copy_1000x750.jpg Views:	0 Size:	51.2 KB ID:	197575 Click image for larger version  Name:	IMG-20230614-WA0005_copy_960x540.jpg Views:	0 Size:	48.8 KB ID:	197574 Click image for larger version  Name:	IMG-20230408-WA0002_copy_1000x750.jpg Views:	0 Size:	50.7 KB ID:	197576 Click image for larger version  Name:	IMG-20230408-WA0004_copy_1000x750.jpg Views:	0 Size:	54.3 KB ID:	197577 Click image for larger version  Name:	IMG-20230408-WA0005_copy_1000x750.jpg Views:	0 Size:	45.2 KB ID:	197573
    I stepped over an envisioned Kriegsmarine Nuclear sub at Deviantart, somehow settled around the novel "Vaterland" of Robert Harris, a 1960's era "what-if Germany won WWII" fiction.
    Click image for larger version  Name:	20181016_095014_copy_1651x1238.jpg Views:	0 Size:	47.5 KB ID:	197579
    Click image for larger version  Name:	IMG-20220827-WA0003_copy_1000x750.jpg Views:	0 Size:	49.9 KB ID:	197578
    The boat was then modified to that image, using a black and grey paint scheme, russian-design emergency buoys, minimal deck detail and the "Puff" casings at the end of the stern planes i always found cool since watching Hunt for Red October with the flawed USS Dallas model. The stern was lengthened with a new cone, the planes were changed from all-flying to a convetional stabalizer-flap type except for the lower rudder.
    Click image for larger version  Name:	20260328_151213_copy_2040x1148.jpg Views:	0 Size:	61.3 KB ID:	197585 Click image for larger version  Name:	20260328_151133_copy_2040x1148.jpg Views:	0 Size:	54.9 KB ID:	197589 Click image for larger version  Name:	20260811_193755_copy_2040x1148.jpg Views:	0 Size:	60.3 KB ID:	197586 Click image for larger version  Name:	20260805_191625_copy_2040x1148.jpg Views:	0 Size:	54.9 KB ID:	197581 Click image for larger version  Name:	20260815_182801_copy_2040x1148.jpg Views:	0 Size:	54.0 KB ID:	197587 Click image for larger version  Name:	20260814_192242_copy_2040x1148.jpg Views:	0 Size:	65.0 KB ID:	197584 Click image for larger version  Name:	20260816_182811_copy_2040x1148.jpg Views:	0 Size:	58.5 KB ID:	197582 Click image for larger version  Name:	20260816_205845_copy_2040x1148.jpg Views:	0 Size:	40.9 KB ID:	197583 Click image for larger version  Name:	20260821_235051_copy_1148x2040.jpg Views:	0 Size:	55.3 KB ID:	197588 Click image for larger version  Name:	20260818_224723_copy_2040x1148.jpg Views:	0 Size:	59.7 KB ID:	197580
    Need to apply draft marks and flat clearcoat. The internals need a makeover,too. I figured my 14,4v twin battery caused the electronics failure.
    • 1118
    Some additional pictures:
ID:	197607 Click image for larger version
ID:	197603 Click image for larger version
ID:	197606 Click image for larger version
ID:	197602 Click image for larger version
ID:	197594 Click image for larger version
ID:	197596 Click image for larger version
ID:	197598 Click image for larger version
ID:	197604 Click image for larger version
ID:	197600 Click image for larger version
ID:	197591 Click image for larger version
ID:	197592 Click image for larger version
      • 14005
      I like what you've done there to up-grade to a CHARLY. However, not to totally steal your thread; you mentioned a nuclear German type submarine.
      Which brings to mind the A Twist Of Sand movie, that suggested that a 'new' WW-2 era German design was nuclear powered and had to be hunted down and destroyed before type propduction could get underway.
      https://youtu.be/Up374m42pJY (33:15)
ID:	197609Click image for larger version
      If were younger I would have taken a stab at modeling that sucker.
        • 1118
        A question to a moderator: if possible, could someone approve my 2nd post, please?
