Micro Snort Pump Voltage
  • ConcreteTurtle
    • Jan 2009
    • 40
    Hi all,
    I'm making some headway on the subdriver 3.5 for the Akula and Alfa, and I've got a quick question.
    What voltage can the smaller snort pump handle? I'm making up some battery packs and I have a choice between 6.6v or 9.9v packs.
    I understand that the Graupner speed 500 is 7.2v but will handle higher voltages ok, but would the MERS switch and micro snort work at 9.9v?
    Cheers.
    CT.
    Originally posted by ConcreteTurtle
    Hi all,
    Cheers.
    CT.
    I have run the pump on 6v and 7.2v, but not higher. I think as we discussed you will find that boat plenty fast on either these voltages. My Alfa has run previously on 6v and 12v. 6 was only marginally slower on top end speed!
      • 651
      You must be using A123 batteries :) i just made up 6.6V a pack for my Revell type VII, and was looking at using the 9.9V for bigger boats too
      • ConcreteTurtle
        • Jan 2009
        • 40
        I sure am, been thinking about them for a while and thought it was time to try it out.
        Going for a 2S/2P to start with, 6.6v /4600mAh should be more than enough to get me into deep water and trouble.
        Are you liking the A123s for your sub? How do you monitor the battery voltage to make sure you don't over discharge?
          • 2604
          Good info on these superb batteries here-
            Where do you buy these?
            • ConcreteTurtle
              • Jan 2009
              • 40
              I've found the best place to get them locally is in DeWalt 36v battery packs for cordless drills etc.
              There are a few sellers on eBay, the pack I'm using cost $175AUD.
              Each pack contains 10 "M1" cells, 2300mAh, 3.3v nominal. There are some really good how-to guides for harvesting the batteries and making up packs in various places on the net. Just search for A123 and DeWalt. (I'd recommend this thread over on rcgroups http://www.rcgroups.com/forums/showthread.php?t=599316)
              I have a hyperion charger and balancer for these cells, but I gather from reading the rcgroups forums, you can treat them pretty harshly without major problems. ie. Some gents are charging their 10S1P packs on location at over 8C! :eek:
              They seem a lot less trouble than LiPo, less prone to catastrophic problems and generally more robust.
              If anyone is interested interested, I'll keep you posted on how it works out.
                • 651
                I only have a 2cell pack for type 7 and still bench testing with it, but no need to balance with two cell and is nice compact size
                • junglelord
                  Banned
                  • Jan 2009
                  • 300
                  Excellent link.
                  Now that is thinking outside the box and using proper pics to document all the information. More information in this context (lots of pics with text) is very needed in this forum and this hobby. Cheers.
                  I'll drink to THAT!
