Spark Arrestment
  • ConcreteTurtle
    • Jan 2009
    • 40
    Spark Arrestment
    Hi Guys,
    I recall reading somewhere here about adding capacitors between the terminals and body of the micro snort pump, and also the drive motor (Its a graupner 500 in my 3.5" SD).
    Does anyone recall the values of cap I should buy for both?
    The info probably hidden in plain sight, but I can't find it..
    Thanks,
    CT.
  • toppack
    • Nov 2008
    • 1124
    The capacitors are installed, to case, on motors that will have polarity reversed during operation, such as propulsion motors. .01 to .1 micro-farads will work.
    On motors that will Not have polarity reversed, such as larger snort-pump, it's best to install a diode across the terminals, such as a 1N4001 diode. Polarity of the diode must be observed.
    But a capacitor can be used on those motors also, it's just not as good a filter as the diode.
    The caps and diodes filter out electrical-noise, produced by the motor mainly, making the power circuit have a more constant DC level.
    If you purchase the MERS E-switch from Caswell, the proper diode for the snort-pump motor is included with it.
    If you use the type E-switch that attaches to micro pump (soldered to terminals), it has on-board isolation and filtering, so caps or diode are not needed.
    See pic:
    Rick L.
      • 13974
      See pic:
      Good dope, Rick.
      • toppack
        • Nov 2008
        • 1124
        It should Be, I Pay my Supplier Big-bucks for It. ;) LOL :D
        Rick L.
        • ConcreteTurtle
          • Jan 2009
          • 40
          Thanks toppack,
          Absolutely the good dope...
          I've looked in my MERS switch bag, and sure enough the diode was down the bottom. I'm using the smaller snort pump because real estate is at a premium in the cut down SD for the Alfa. I'll add this diode across the pump when I install the MERS.
          I'll also go ahead and add a couple of caps to the main motor as suggested.
          Thanks again, much appreciated.
          CT.
          • toppack
            • Nov 2008
            • 1124
            Great,
            the instruction sheet with the MERS shows how to install the diode with proper polarity. It will 'Make Smoke' if put in backward.
            The capacitors value is not too critical. Around .1 microfarads is a good size since they are physically small enough and have enough capacitance to do a fair job of noise filtering.
            Rick L.
            • junglelord
              Banned
              • Jan 2009
              • 300
              Make smoke and stink too, good dope, must be skunk weed....LOL.
