Charging the on-board propel vessel
    After chilling down the propel container within the Subdriver....is there a rule of thumb for how long it takes to fully charge the propel storage vessel with propel?
    I know this will depend upon the size / volume of the storage vessel - but I still think I am not charging correctly.
    John
    • 13982
    John
    You can over-fill the on-board bottle and that would be dangerous (a blown flexible hose could be the result). I do this: Charge the on board bottle, then vent the entire contents quickly (you only put a little in, the transfer of liquid stopped the moment the pressure in the can and on-board bottle equalized), this chills the bottle, lowering its energy. Charge again and hold the charging adapter in place a full five-seconds -- this time it took much more liquid to reach the same pressure in the on-board bottle as the can, and you should have filled the on-board bottle about 1/3 full of Propellant, which is the desired amount.
      Thanks David,
      I see what I am doing wrong is not emptying the enitire contents to chill it down.
      I was merely just depressing the fill valve and letting a small blast out.
      In other words I was not chilling the bottle down propely, therefore restricting the subsequent fill.
      John
        • 13982
        Thanks David,
        John
        You got it, John. Go get 'em!
        • Nuke Power
          Banned
          • 277
          Good stuff never knew that. Perhaps I can get a bit more thrust out of my missiles now.
          David what would you recomend for a substate on missiles that is resistant to propel and still light weight.
            Kevin - a little off your question but what is "substate"?
            John
            • Nuke Power
              Banned
              • 277
              Oh a substate is when you dont prof read and forgot to type one of the required letters making a whole new one in the process. The intended word was substrate.
              • toppack
                • Nov 2008
                • 1124
                Which in that case is a durable base material that the missile exhaust pushes against as it is exiting the sub, that will prevent damage. (like blow a hole in her bottom):D
                Rick L.
                • Nuke Power
                  Banned
                  • 277
                  More like a material that doesnt get brittle over time due to reacting with the chemicals in pvc and blow up like a little handgrenade killing the maker.... you know that kind of stuff.
