Robbe Futaba F-14 Navy Alternative
  • SubICman
    No problem. It's easy, doesn't violate the FCC and was actually a fun little endeavor. Putting my navy electronics background, applied electronics and EE degrees to work for good....lol
  • hywel
    THIS IS AWESOME!!! Thanks so much SubICman for the guide, I'll be doing this as soon as I get my hands on one!! Absolutely epic!
  • SubICman
    Originally posted by hywel
    Thank you all very much - I've found some options that might work.I'd be interested to understand how you converted to 75Mhz SubICman - sounds like I need to cannibalize an existing 75Mhz unit or find one with a swappable module. Cheers!
    It is fairly simple. You make a harness from a servo lead and a piece of long pin header and jumper wire from an electronics or Arduino prototyping kit. My assignment of servo lead wires is as follows" Red negative batt., Black positive batt, and white is PPM.
    Cut a bread board jumper in half for the antenna adapter. ( the short white lead with the pin on the end)
    Click image for larger version  Name:	20221018_083721.jpg Views:	0 Size:	64.1 KB ID:	165687Click image for larger version  Name:	20201226_073026_310b0163b754509aab6c9651d16162fe7d2874f3.jpg Views:	0 Size:	66.7 KB ID:	165688
    Then you unsolder a jumper from the main board. This is the power to the Radio on the board. It is the spot with discoloration around it that the arrow is pointing at.
    Click image for larger version  Name:	20221018_083408 fixed.jpg Views:	0 Size:	73.2 KB ID:	165689
    Unplug the Antenna from the board.
    Click image for larger version  Name:	20221018_083258.jpg Views:	0 Size:	54.8 KB ID:	165685
    Then plug in your harness, antenna lead and your FM module. The positive lead (Black) on the trainer is to top of the trainer jack when looking at the mainboard so that the control jacks are closest to you. Remove the bracket for the multi switch, and the FM module is double sided tapped into the multi switch bay, Velcro could be used also. Done!
    Click image for larger version  Name:	20221018_083158.jpg Views:	0 Size:	80.0 KB ID:	165686
  • hywel
    Thank you all very much - I've found some options that might work.I'd be interested to understand how you converted to 75Mhz SubICman - sounds like I need to cannabalize an existing 75Mhz unit or find one with a swappable module. Cheers!
  • SubICman
    I have a single stick fF16 That was originally 40 Mhz that I bypassed and added a Futaba 75 Mhz module to. I also have a twin stick F-14 in 2.4 Ghz. They can be found,, just need to be patient. They are very easy to mod away from 40 Mhz to 75 if your in the states.
  • gantu
    Hi the F models of the remotes are very cheap in Germany I saw some for 30 to 40 euros used. If I can help you out I can send them to you?
  • Sinksalot
    I seen Robbe F-14, F-16, FC-18 and FC-28 where people added a twin stick. The main problem is finding one of those transmitters. There where never many in the US. Most people I know buy the FC-18 or the FC-28 as there module transmitter and easier tor run by adding 72 or 75mhz module. But then you need to find and buy a twin stick to install. For both the transmitter the twin stick, everyone I know had to buy them in the UK or Germany and ship them to the US. Which drives the price up alot.
  • gantu
    See this
  • hywel
    The F-16's seem just as rare, it seems. I'll just keep looking, thank you!
    You could use the similar F-16 as well or find a standard F-14 and a twin stick module and install it yourself. I heavily modified my F-14. Click image for larger version
  • hywel
    started a topic Robbe Futaba F-14 Navy Alternative
    Howdy, all. Are there any good alternatives to this radio, it seems to be unavailable :/
    Cheers
    - hywel
