hi, im currently making th wtc for a t class sub, i am going to make a static dive tank using a pump to fill then using the pressure of the trapped air and a solenoid valve to empty.
would a graupner 12v fuel pump have enough force to do the task and what type of solenoid valve would be best for the job, also what would be the best way to work this off a transmitter?
thanks lee
thanks lee
