Question about radio reciever and transmitter
  • Dustyb123
    • Apr 2016
    • 6
    Hi,
    I recently bought the Seawolf Submarine Sub-driver and I was wondering what type of radio receiver and transmitter I should use for it.
    Is 75mhz 8 channel correct? I'm planning on using it in a pool.
    Thanks.
    • 13988
    You can get away with a four-channel r/c system, but the eight-channel is better -- with that you can use the bow planes.
    • Dustyb123
      • Apr 2016
      • 6
      Could I still control the bow planes with a 6 channel radio?
      I'm having a hard time finding a 75mhz transmitter, is there a type you would recommend?
        • 13988
        Yes. Any system you can find will do.
          You're using it in a pool? Just use an EASY Sub-driver with a 2.4ghz radio.
          You'll need to make the rudder bigger.
          The Seawolf is hard to turn, especially in a pool.
