where to purchase dive planes
  • robert lipsett
    • Mar 2010
    • 49
    I am working on a type 7 u boat it is about 5 1/2 feet long and I would like to find some dive planes for it that are made of resin or similar material. Where may I purchase such an item
  • Slats
    • 1776
    Which kit manufacture made this, or have you built it yourself?
    sigpic
    • robert lipsett
      • Mar 2010
      • 49
      its a kit that is over 20 years old that I have been trying to build off and on. I can not remember who made the kit nor can I find the directions. it was supposed to have watertight built in compartments but they leaked badly so I ripped them and am putting in a wtc. I have wooden dive planes now but since it is being redone I thought that maybe I would update to something better and more water resistant
      • Slats
        • 1776
        Gotcha -if you post photos it might help too.
        If you can figure out from the size of the boat you have the exact scale there might be a manufacturer of a current kit in that same scale who could sell you a set of planes. Other than that if you have plans and the original wooden ones you could coat the wooden planes in resin to W proof them or perhaps make your own from making a master and moulding them.
        J
        sigpic
        • robert lipsett
          • Mar 2010
          • 49
ID:	58396Click image for larger version
          5 1/2 feet long. My hole in the water into which I pour money. I want to get it finished
          • Slats
            • 1776
            Well I am not the U-boat expert, but that does not look entirely scale to me - others jump in here.
            Robert - you need to work out what scale that is - measure it exactly (i.e. is it exactly 5 1/2 feet) and then compare that against what type 7 it is meant to be. With scale know there may be a manufacturer that makes a kit that might be able to sell you dive planes.
            J
            sigpic
            • robert lipsett
              • Mar 2010
              • 49
              yes it is exactly 5 1/2 inches it is smaller then a 1/32 model which would be 82 inches long
                • 13419
                Oh, for Christ's sake!
                Make 'em yourself and stop using up my band-width! How hard does this have to be?
                Or ...
                ... Go to your local Dive Plane supply store and buy a set!
                • Rick Teskey
                  • Jan 2009
                  • 265
                  cut a pair out of card board too size and shape that looks good and fit .
                  Next transfer shape too some 1/8 thick fiberglass sheet or styreene or brass sheet and cut a slot for a shaft , glue shaft in place and fill with resin or glass bondo and finish sanding too shape, encapsulate in resin and paint, that should work.
                  You are doing a 1 off not a production kit or use brass sheet and make 2 pieces and sandhich the shaft between them and solder together and fill and sand .
                  You are not making a museum quality piece and if anybody does not like what you have done tell them too polietly go f*** them selves, it works for you and you made it your self !!!
                  Rick
