perastaltic pump
  • Rick Teskey
    • Jan 2009
    • 265
    perastaltic pump
    Good day
    Dave if you took one of the planetary gear boxes you are using for the torpedo stripeing rig and attached a bar with two rollers attached too the out put shaft and some tubing you have the making for a pump.
    Tor
    • 13528
    great minds think alike, Rick.
    • Rick Teskey
      • Jan 2009
      • 265
      Pump
      Here are a few shots of a pump I made for proof of concept
      The pump housing is 2.375 " i.d. abs cap and I am using a .250 i.d surgical tubing.
      This was just down and dirty so I did not install and bushings or gear reduction.
      3 teflon rollers attached too an aluminun disk pretty simple and pumps great .
      I drove the test piece with a drill just too see if it would work.
      Sloted disk or rotor arm could be made so tubing size and amount of compression could be adjusted
      Rick
        I think I've found a pump. I've ordered a couple and they'll be here in a few days. Stand by!
        • ADDINGTON
          • Sep 2008
          • 80
          Mike,
          Any update to the ordered pump mentioned above?
          -Kerry
