Today's R/C Boating At Mount Trashmore
    • 13951
    Well, for the first time this year (other than the recent Carmel SubRegatta) I got to play with one of my toy submarines. I spent the morning getting my Moebius SEAVIEW ready with the addition of a set of flood-drain holes near the bow, followed by the normal pre-mission checks.
    Operation of the model at the lake revealed that in a bit of wind the boat is prone to being blown over on its side a bit too much. I'll have to shift some of the foam higher up to raise the metacentric height.
    Other than that the boat handled well and the additional flood-drain holes did the job of reducing diving time significantly. All went well till the end of the internal antenna somehow found its way into the port propulsion tube, wrapping itself around the pump-jet rotor, stalling the motor, burning it out. Something to add to the 'to do' list on the chores to do tomorrow.
    Had a good time with the local r/c boaters. The festivities continued at the the local all-you-can-eat where we all enjoyed an evening meal and good company. Talked with the guys about this years Carmel SubRegatta, and some of them indicated a serious interest in attending next years event -- we'll see.
    Anyway, play-time's over. Back to work. Mr. Caswell hit me up with more PO's last week and I have to get product out the door this Tuesday.
  • dave_mcwhite@cox.net
    • Sep 2009
    • 22
    Seaview Bow Blow Openings
    Tell us more on why you needed the new forward blow opeings? How did you determine where to cut them and the overal area required? Was this a last min. fix or had you known of this issue long? I am finishing up my Seaview and still have time to cut these holes if needed. Do you think that if you had left the origional display stand keel oenings alone, that this would have provided the needed water flow?
      • 13951
      Without the new flood-drain openings and the pump-jets going 'ahead', a partial vacuum is created within the hull that prevents filling of the ballast tank when the vent valve is opened. The opening bust the vacuum so the boat can submerge while underway.
      Start with the two open stand holes, if that's not enough open up the holes near the bow like I did.
      • Slats
        • 1776
        nice to see you getting your own stick time in.
        Any photos of the boats underway?
        best
        J
        sigpic
        • Slats
          • 1776
          Ps - thanks for posting the photos of drilling those holes out - just learnt something with the low tack tape over the top to prevent filing causing fraying edges.
          I have been using other tape (more sticky) that did not seem to work that well in this regard
          J
          sigpic
            • 13951
            best
            J
            Hey, John! How's it going? No underway shots, sorry. Too busy having fun.
            On another topic: Have you been following my building thread over at RCGroups on converting (correcting) the just released 1/72 Lindberg-Hawk I-53 Japanese, Kaiten carrying submarine? I know how hot you down-under guys are for anything in 1/72.
            Also, did Chuck get the word out that he's got a commit from a GRP manufacturer to produce that much wanted 1/72 FOXTROT kit? I'll be involved in a small way.
            Film at eleven.
              • 651
              Its going to be sweet
              • Slats
                • 1776
                Film at eleven.
                Yes to all that - have e-mailed you.
                Best
                J
                sigpic
                  Lest we forget! This Japanese sardine can is detracting The Wizard from torpedoes, so don't encourage him! :wink:
