Propel vs Compressed Air
  • junglelord
    Banned
    • Jan 2009
    • 300
    Have you considered the cans of computer cleaning "air" that come in a can with a trigger. If you have a Costco there they may sell them in three-packs. It is easy to adapt the trigger to a tire filler attachment if that is what is being used on the boat. It is a lot cheaper than Propel
    Is it true you can run compressed air vs propel.
    Being on a pension, I was wondering?
    Dean
    • 13988
    Dean
    Sure, why would you?
    You can't bang up a propel system with compressed air an get any more than a half-blow. 70 PSI of air in a typical on-board bottle has very little energy potential.
    • toppack
      • Nov 2008
      • 1124
      With propel system liquid is converted to gas when it's dumped, so you get a much larger volume of gas per tank full, than with air.
      Rick L.
        • 2642
        Dave what is propel gas made up of, is it mostly butane based?
        I know a lot of modellers over here used butane for gas systems. You do have to be careful with it as it's highly flammable (so no smoking around your boat), plus it can eat some kinds of rubber, so I'm not sure how thta will work with Dave's stuff.
        • toppack
          • Nov 2008
          • 1124
          I found out that It contains:
          1,1,1,2-Tetrafloroethane, (which is 134A, a freon substitute, good for the enviroment)
          So we can use the same stuff we use in our Car AC systems. Of course it's almost as expensive, unless you find a surplus deal somewhere.
          No wonder it gets so Cold when converted to gas, and cracks the plastic, that's what 134A is supposed to Do (get very Cold)! ;)
          Rick L.
            • 2642
            Ah right, very different animal to butane then.
              • 13988
              Butane is a good substitute and no more harmful (plenty harmful) than the other hydrocarbon bearing liquefied gas 'propellants'. They all attack natural rubber, some more than others. The typical tire valve rubber element is a hydrocarbon tolerant material, but natural rubber products (the clippard valves come to mind) are destroyed in short order when subjected to pressurized propel and Butane. The air-brush propellants marketed by Tester's, Paasche, Badger and others are pretty much a methane-butane mix. Very flammable, very reactive to natural rubber.
              We used to use Freon-12 as the expandable gas of choice, but the government weenies took that away from us and gave us that stupid substitute. Hence the use of air-brush propellant and the 'dust-off' type liquefied gas.
              • toppack
                • Nov 2008
                • 1124
                That's what I thought it used to be, but the air-brush propellant, I got recently from Tower-Hobbies, says 134A on the cans. Maybe the EPA made them change over to 134A?
                It seems that the 134A version would be the best to use, for several reasons. :)
                Rick L.
                • Nuke Power
                  Banned
                  • 277
                  I sent Mike an option for cheaper gas than propel w/ an equal number of blows. he posted it somewhere but, it involves making your own little adapter and a can of compressed air (like the type that are used on electronics) You can pick up a 3 pack for like 5 dollars at walmart.
                    • 651
                    Need Viton rubber for hydrocarbons
                      How about using the small CO2 canister used on life jackets and BB guns?
                        WHy not simply buy this from us.
                        ABPT Propellant - 15oz $9.95
                        It 'ain't broke'!!
                          I did try this and although it all worked, the adapter was a little fiddly to get to convert.
                          I got a severe attack of the CBB's! (Can't Be Bothered) That happens a lot just lately.
                            • 13988
                            CO2 at room temperature, in order to remain in the liquid state, has to be maintained at around 800 PSI.
                            Lawsuit city. No thanks.
                            • Slats
                              • 1776
                              That Stinks
                              Gas gotta love it
                              That Stinks
                              sigpic
