More Negative Vibes! :(
Any smaller and the standard sized battery-connector and wires would not fit in.
(picture shows that it is a tight fit, connector is visible inside) That size connector is needed for low-resistance contacts. There may be high current since there are 6 servos (4 are high-torque), 3 motors & their control circuits and the video-camera/transmitter.
I haven't even started putting in the Stereo-System! :D
As stated previously:
I have Leak tested it.
The forward WTC is one I designed and fabricated.
The SD is David's 3.5" (2 chamber) unit.
