Please help. I'm having trouble with torpedoes
  • DUNLOP
    • Jun 2015
    • 3
    I've bought two of the Merriman torpedo tubes for my submarine project. I took out the shuttles and now I cannot put them back in. For the life of me, I can't figure out how to put the small ball AND the shuttle back into the control tube. There's just no room to get the ball seated and then push the shuttle in, or to push the shuttle in and then fit the ball.
    Is there a trick to doing this? They make it look like shuttle changeover is a "no brainer".
    • 13980
    You people!
    It is a no-brainer. I said so!
    You're trying to introduce the locking ball through the shuttle cylinder -- bad hockey! You introduce the locking ball through the breech end of the torpedo tube. Duh!
ID:	98863 Click image for larger version
ID:	98864 Click image for larger version
ID:	98865 Click image for larger version
ID:	98866 Click image for larger version
ID:	98867 Click image for larger version
    Order of assembly is everything:
    1. remove the breech block (loosen the interlink set-screw and pull the breech block clear of the launcher)
    2. install the shuttle and place it in the 'launch' position
    3. into the breech end of the tube, place the locking-ball into the hole for it and push it down to engage the shank of the shuttle
    4. re-install the breech block and cycle the launcher to the 'battery' condition (ready to launch)
    5. test
    6. five Hail-Marries and a promise to never trouble me again!
    You people!
      • 651
      He failed to mention you need a team of elf slaves, and Jedi powers
        • 651
          • 13980
          It's a given. You DON'T have a stable of el*** slaves, and the Force (the Dark one, of course) working for you???!!!!!....
          If this **** were easy, every Schmuck would be doing it.
          • DUNLOP
            • Jun 2015
            • 3
            Ouch. Didn't mean to offend you. Perhaps a good idea might be to include these instructions with future orders as it is definitely not a "no brainer" until after you've had it explained and have done it yourself. Oh, and "never troubling you again" - does that include ordering more units?
              • 13980
              Touchy, touchy.
              The instructions are adequate. You did not study them enough.
              You thought I should help you out then give you a rim-job as a form of thanks?
              Yeah, maybe you would be happier with a different supplier of 1/72 torpedoes.
              Rotsa Ruck.
              • DUNLOP
                • Jun 2015
                • 3
                Ah, c'mon David, if I wanted to give you $260 for a couple more torpedoes you'd sell them to me wouldn't you? I think this "I'm a real *******" routine of yours must just be your shtick! Down at your core you're a real teddy bear, right?
                  • 13980
                  Awerr shucks (tracing pattern in sand with big toe).
                    • 3753
                    Dunlop,
                    You hit the nail on the head. David will test people and poke at them, but once you are past that, I have not met a more genuine, non phony, real person who will bend backwards to help you succeed. I have seen him (read some of the postings) take a Sub-Driver that a person has used for years and fix it for no charge. That is customer service. He truly wants to see those that desire to build a sub succeed. His gruffness puts some people off, but look beyond that and like you said he is a Teddy Bear. Since we are getting all mushy, group hug anyone?
                      • 13980
                      Dunlop,
                      **** all of ya!
                        • 1647
                        Where are the old days of grumping?, and whipping or using a thistle, group hug?, YUK !!!!, i'm getting old.
                          • 3753
                          Manfred, I am sorry, I blame the drugs I am on. What was I thinking, bring on the wrath!
                            • 13980
                            I'm waiting till you're off the pain-med's. I want you to savor the beating I owe you.
                            Nothing personal. Just business, my friend.
                              • 3753
                              Duly noted.
