Anyone working on a 1/35 Bronco R.C Seehund
  • george
    • Dec 2010
    • 731
    Hello
    I recently bought a 1/35 Bronco Seehund and I have been thinking about converting it to a R.C Static diving submarine.
    I wounder if anyone here has done it or is working on one? I know someone did one in the U.S as a dynamic diver but I wanted to go with the static version.
    Please show pictures of your work so I can get tips from you for mine.
    Thanks for your help.
    George
    • 1587
    George,
    That would be quite a project, i wonder if it's possible to build it as a static diver, i do have a epoxy Seehund model 1:35 in the cave as a future project.
    The electronics are small enough there days, i would build it as a dryhull with a radial split, giving you the most room inside, you're sure going to need that.
    • small sub guy
      • Dec 2009
      • 45
      I saw this at a SubRegatta
      • george
        • Dec 2010
        • 731
        Hello small sub guy
        Can you give me anymore details about the sub you saw at the SubRegatta? Name, scale etc.
        George
        • small sub guy
          • Dec 2009
          • 45
          1:35 scale dynamic diver Seehund.
          With a 1 3/16 OD X 6 1/2 long tube.
          Mare Island SubRegatta 2014.
          Here is another pic
          • zhuravlik
            • Mar 2011
            • 95
            Seehund 1/72 ICM conversion.
            • gantu
              • 418
              I Found this on my harddisc is the 1/35 scale Seehund
ID:	93431Click image for larger version
              Regards Gantu
              • george
                • Dec 2010
                • 731
                Hi gantu
                It`s been a long time since I have read your posts. How are you doing? Thank you for the pictures of the S.D I have read that same article before and I think I will use the same size WTC for my project. I will try to take as many pictures for a build report here also.
                Thanks Again for the Help everyone.
                George
