working up an old SubTech ALBACORE kit
  • roedj
    • Sep 2008
    • 563
    Or the 3" SAS SD (cough, cough)?
    Dan
      • 13629
      Yes to both of you -- the 1/60 ALBACORE is big enough to take either the 3.5 or the 3-inch SD. I've got Mike changing the ad copy to the 3" SD -- it was listed months ago, but I miss-stated its use and diameter (matter of omission). Anyway, Mike is changing the copy in the catalog so you can more easily find that SD there.
      • Slats
        • 1776
        The ingenious way David has done the aft stern cone piece means that his GRP hull can be mated to just about any phase stern set up that you want. David do you suggest a mechanical "screw" connection for the stern cone to the GRP lower hull or combination of screws and fibreglass?
        The 3" SAS SD that I have purchased and will be soon decking out my style (which means a custom tray). In my view, if you have the funds to spring for a dedicated SD for this, the 3" SAS is the preferred option as you will keep the height of the SD lower in the hull than the 3.5". But like David says the Skipjack unit will fit it and amply support operations.
        In my case - I viewed all of the previous literature on the plastic kit, the 3" D&E WTC that David mounted for many years yielded a better than average turning boat. When I found out that David was producing the GRP version I wanted to buy a dedicated SD for this project. This will be my first all Merriman engineered sub, i.e. GRP hull kit plus 3" state of the art SAS SD. To me that translates to Bespoke on Bespoke - worth every penny.
        There are so many interesting ways to portray the Albacore. I'm saving the Albacore Forerunner book for my vacation, but in the meantime I'd love to find some good dope on paint schemes that underpinned each Phase of the boat, unless of course the Forerunner of the Future text is the way to go.
        I take it David you will be including WTC saddles for both 3" and 3.5" diameter SDs?
        J
        sigpic
          • 13629
          I finally completed the ALBACORE. Here's some video shot from the surface. Hope to get some u/w shots in tomorrow. Enjoy!
            • 3670
            Wow, that has an amazing turn radius. I notice a small amount of flutter in the sail plane, but the underwater performance rocks! Look forward to the underwater video. Well done sir.
              • 13629
ID:	98609 That's the dorsal rudder. Which, on this model, is active and responds to roll. (Actually, the phase-2 ALBACORE did not have an active dorsal rudder, so I'm a bit out of scale with this display). A fortunate accident: the dorsal rudder servo chatters a bit when the LPB is running -- which turns out to be a useful visual cue, telling me that that pumps working when I command it to. So, I'm not going to do anything about the twitching you see in the video.
              The excellent depth control during radical turning commands -- which would be all but impossible on a normal boat -- is because the dorsal rudder works to keep the boat from rolling inboard (a consequence of sail 'foil' roll force) as the angle-of-attach shifts when rudders yaw the hull about.
ID:	98610 Click image for larger version
ID:	98611 Click image for larger version
ID:	98614 That control surface also contributes significantly to the boats total drag in a turn -- a great way to recover from an unwanted 'depth excursion'!
              I also posted this video to Make John Slatter crazy(r).
                • 3670
                [ATTACH=CONFIG]31410[/ATTACH] That's the dorsal rudder.
                Thank you for the correction. Now that I think about it, it was dumb to call it a plane because the controll surface is vertical in orientation.
                Great, more name calling and knashing of teeth! After that little video, I think it will drive more people crazy. So, when will this come to market?
                  • 13629
                  Not dumb, as it effects a torque about the roll axis, it would be properly called an aileron. But, I digress!
                  Name calling a specialty, pal! It's what I do.
ID:	98615 The Caswell-Merriman 1/60 kit of the ALBACORE has progressed to completion of the masters, next job is the tooling. Then crank out the kits which will feature GRP hull and resin sail and appendages, with cast white-metal detail pieces.
                  And never mind what Skip or Matt think about this new 1/60 ALBACORE kit. Skip's hanging it up, and Matt has failed to crank out a new kit in ... what ... ten years?
                  With regard to Matt Thor: He had a good run (with my help) in the 90's. But he's long since run out of gas. So much promised in the last few decades. So little delivered to the buying public. So, for my part, enough courtesy waiting on Matt Thor to get product to market; enough of his many announcements of 'new' product -- that dodge is getting old! Me and Mike are plowing on.
                  Poop or get off the pot, Matt! Lead, or follow. Pick one.
                  "Why don't you let us take over from here, Emil?"
                    Great job there Dave. We can see that you didnt have a video taking person with you today, but you improvised and got it done anyway. Good Deal! We are getting closer to a Phase one Albacore at some point. I cant wait. Its nice that you have the use of that pool.
                      • 13629
                      Yeah, Mr. Tripod to the rescue!
                      The initial release will be like what Skip did: phase-2. Then I offer phase conversion kits to cover the other four (they want polymer injection, they do it themselves!).
                      The guys at Lynnhaven Dive Center have been so kind over the years -- it would have been so easy to say 'no'. But, they gave me a chance -- and I make it a point to let them drive the toys when they have a few moments away from the sales floor. Gotta keep greasing the wheels, you know.
                        • 651
                        1/72 Alfa next please :)
                          • 2503
                          If you're filming on your todd, and need to pan around I find a small 808 keyfob cam attached to the peak of a baseball hat tracks the line of sight pretty well. I took some film of my flying wing foamy thingamybob, which cranks along to try it out a few months back.
                          • ffr2608
                            • Oct 2009
                            • 331
                            Nice work!!!!
                              • 13629
                              I like that! I'll do that next time. Thanks, Andy.
                              • Peter W
                                • May 2011
                                • 511
                                #30
                                Mr M. Wow that thing looks good in the water. Love stability of it and the responsive control.
                                Peter
                                P.S. All that water and you drive it straight into the buoy....
